#504203 12/19/02 05:15 AM
Well my batter light's on, I thought it was corrosion on the posts but after cleaning them no luck. I have noticed a squealing sound when the throttle is increased. I'm wondering if this could be a result of a bad serpentine belt. I do know that I need to replace it. Also wondering if it could be an alternator that's fading. I notice no power decrease and the battery light flashes on and off during acceleration and braking. (that's why I thought it first could have been a bad connection with the cable. That's not it though)
'03 Protege 5 MTX '02 Mazda Protege LX MTX former owner of: 96 Contour GL 2.5 ATX
#504204 12/19/02 05:18 AM
replace the belt, see what happens. if alternator was going i'd think your lights would dim,etc.
#504205 12/19/02 05:47 AM
You might be having the same problem I had. I have a 99SE V6 with 26,000mi. The car spends most of its time sitting so I thought my battery was just going low. Figured I wasn't driving it enough. Had my battery charged and drove the car for about 30 minutes and the battery light would come back on. Sounded to me like the alternator wasn't producing enough juice to keep the battery charged. If I drove the car long enough this way the battery would run down so much that the car would die.
Took it to the dealer and they said they couldn't find anything wrong. Of course the battery light never came on for them. I think they just let the car idle...rather than driving it which would have put a greater load on the charging system. I told them I thought the alternator was faulty but they said the charging system tested fine.
I reluctantly took the car back from the dealer and drove it around until I managed to get the light to come on. This time I brought it to them...still running (and fortunately before the car died)...with the battery light lit. This time they tested the system and they concluded that the alternator was indeed bad.
I have put about 500mi on the car since they installed the new alternator in July and I haven't had the problem since.
Good luck!
99 Contour SE V6 Sport ATX (white w/gray interior) 17" ADR DSL wheels, tinted windows, Pioneer DEH-6200, Infinity components, Polk 10" sub, two JVC amps (600W & 480W), Ungo MS5000. http://pweb.netcom.com/~spencer8/99se.html
#504206 12/19/02 12:06 PM
Battery light only illuminates when the alternator isn't putting out ~14V. It could be the voltage regulator.
Curtis 3L 'Oval Port' 98 Black SVT 180.5HP/178lbft '03 Black Sport Trac
#504207 12/21/02 05:56 AM
Got it looked at today. Originally came up as an alternator, $198 for a rebuilt and over $200 for labor, Took it apart and found a corroded wire, replaced the wire and $160 later (new serpintine belt ($25) and 1.5 hours labor!) it's all fixed. By the way the cheapest alternators were through ford, which I thought was quite interesting.
