Posts: 1,228 |
i haven't noticed this since the last time it rained, but it seems that when it's raining outside - my speedo will "zero" out and quit working - but after a minute or so, it will jump back up to speed... the "gas" light turns on for 2-3 seconds when it comes back to "life"... i can't replicate the problem unless it's raining outside. what could this be?
Posts: 21,653 |
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 635 |
Let see now in a couple months mother nature will fix it? Or is that only in Northern Calif?
Paul
Paul
98 Mystique LS 2ea (07/97)(08/98)
Posts: 3,632 |
I had the same problems once, only it happened over bumps. My speedo would go out.
It was fixed under warranty. I think something was loose. I forget what happened exactly. Had it fixed at the same time my PATS stopped me from starting my car.
"Cobb - It's not just for corn anymore!"
Posts: 23 |
Had the same thing happen a long time ago. Never figured out what it was, it just went away.
'98 Contour LX-White
2.5L ATX
94,000 miles
KKM Tru-Rev / FMS Wires
19mm BAT rear swaybar
Posts: 6,910 |
I do not remember but it might be the VSS. father had this happen after he got his car, he said he spraid something with silicone spray and it took care of it, in 96, but it just happened again. I beleive it was someplace on the transmission so that is why I think it was the VSS
- 95 Mystique LS - Zetec/5spd
Posts: 1,228 |
Originally posted by brapple: I do not remember but it might be the VSS. father had this happen after he got his car, he said he spraid something with silicone spray and it took care of it, in 96, but it just happened again. I beleive it was someplace on the transmission so that is why I think it was the VSS
VSS? V-something Speed Sensor? huh? what is that?
Posts: 6,910 |
vehicle speed sensor I am pretty sure reports the speed of the vehicle to the PCM and the speedometer, it also is used with cruise control
basically it takes the place of a speedometer cable that older cars have, but it also reports important information to the computer and some other systems
Posts: 9,602 |
Originally posted by brapple: vehicle speed sensor I am pretty sure reports the speed of the vehicle to the PCM and the speedometer, it also is used with cruise control
The PCM gets it's signal from the ABS wheel speed sensors. (actually probably from both, but it definitely uses the wheel sensors for calculations) The latter two do get their signal from the VSS.
2000 SVT #674
13.47 @ 102 - All Motor!
