#502162 12/16/02 05:23 PM
if i pull the engine and the tranny thru the top,how do i get the tranny past the master cylinder and the batt holder.
can i just remove the engine only or do i have to pull them both together.i have a 1995 zetec 4cly with a auto tranny.
i am looking for the quick and easy way out.
You can remove the transaxle (and subframe) by dropping them down with the car on stands. Haynes manual suggests lowering the engine, tranaxle and subframe as a unit using a special support. But then you would need to raise the body high enough to clear the engine. I don't know if the engine alone could be raised thru the hood after the transaxle was removed. Has anyone tried this?
Yes it can be done, I believe David Z did his 3.0 by lifting his engine through the hood.....
97 Zetec MTX Sport Mk1 Mondeo Morettes & Clear corners Full SVT kit w/ Molded Mirko Splitter, Carbon Fibre Hood Ground Control coilovers w/ Koni adjustables, BAT anti roll bar Pics of my rides in my profile! Rally drivers do it sideways......
Wouldn't it be alot easier to OPEN the hood?
~*TJ*~ 97 GL Sport Zetec MTX ~*RIP*~ Connie~*1/21/02* Sold the Zetec, now the prouud owner of an 01 VW GTi VR6 - Sold the GTI now have 97 Mustang Cobra
I have pulled a 3.0L contour hybrid out the top of the hood before,it can be done. Lots easier if you leave the trans in place, though...
-Jeff -"Buck Futter!!" My Ride! http://members.sounddomain.com/sideoftheroad
Wise arse!!!
Wise arse!!!
I had to take that shot, it was to tempting to pass up
