I'm not sure about which SVT mounts will fit on the ATX, but firming up the one on top of the ATX helps reduce wheel hop quite a bit. When the tires break loose, they keep turning instead of that horrifying shudder. I used polyurethane caulk from home depot to fill the gaps in the mount.
