Posts: 30 |
I'm getting moisture in the corner's of my trunk behind the wheel wells, no place else. I've seen the posts from the archive and I want to know where QWICSVT put the sealant, and another post described removing the rubber trim around the trunk and running a caulk bead, where was the bead and did it affect replacement of the rubber trim? Any help is appreciated.
On an unrelated note any info on fog bulbs that'll shine like 4100 degree color temp but not melt stock lenses?
-blest92.5 '99 1841 of 2760
Posts: 21,197 |
From the archives.
The part number is F5RZ54280B62A. It's called a grille. It's not too much work. You need to remove the plastic piece covering the trunk lock area and then remove the carpet on the side of the trunk. To get the plastic piece off, you need a phillips screwdriver for the four plastic screws (be gentle with the screws). There are also two plastic pop rivet things you need to remove. The carpet is held in place by a plastic screw and two plastic pop rivets. Once you remove the carpet, you will see the black plastic vent that you just bought. Remove the new gasket from the new vent; unfortunately, you don't use the new plastic vent because you'd have to remove the bumper to install the whole assembly. The vent snaps into the sheet metal. Remove the old gasket from the old vent, clean the vent and sheet metal as best you can (for a good seal), and then insert the new vent seal into the old vent, making sure that you insert the curved part of the gasket into the curved part of the vent. Make sure that the new gasket is firmly seated in the vent. This takes some time to work the gasket into the vent because there is not a lot of room for your hand, but if you are patient, the whole gasket eventually will be well seated in the vent. Snap the vent back into the body, being sure to position the bottom of the vent in the metal first. You shouldn't see water leaking through the vent anymore.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 30 |
Todras, thanks for the post I appreciate it.
-blest92.5
Posts: 1,110 |
I suggest having someone use a hose to run water on the car while you sit inside with a flashlight before you do anything. I had a leak in the vent, backglass, and the rubber gasket thing around my non-power antenna. Good luck. I chased my leaks for many months before I "plugged" them.
'01 Escape XLT V6 on S100
CDT Audio/Ascendant Audio/Rockford/JBL/Knukonceptz setup
'00 SE Sport ATX
Posts: 30 |
I'm going to try that next, since it only shows wetness in the corners I can't help thinking it's coming in behind my corner lights somehow. My trunk has a seal foam applied inside the trunk in all the seams and corners (I don't know if that's factory, dealer or former owner applied), I've never had water in the well where my spare is either. I think I would notice water there if it was the gasket.
Thank's for the advice,
-blest92.5
Posts: 16 |
I just noticed about 2 inches of water in one of my tail lights. Not sure how it got in there, since there are no cracks in the lens. If the water got high enough, I suppose it could leak out the bulb holder hole and into the trunk. I sucked the water out with a siphon pump that you attach to an electric drill.
95' Contour SE ATX - Killed by rogue whitetail
97' Cadillac Catera
98' Expedition XLT 4x4
Posts: 29 |
I am still fighting a trunk leak that sounds identical to Blest's. I was running water down the backglass while lying in the trunk with a flashlight and didn't see any water. I think I have to investigate the vents further. What puzzles me is that the corners get wet in the car wash or even just a light rain while the car is parked. Is it possible for water to leak in through those vents if the car is parked?
