#501124 12/14/02 08:40 PM
I have these tires: http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=ECSTA+Supra+712&vehicleSearch=false&partnum=245WR6ES712 on the way... Any thoughts? Am I going to have a problem with rubbing or anything?
#501125 12/14/02 09:37 PM
Shouldn't, because I'm running 225/50/16's on 16"x7" wheels and I've yet to rub.
JaTo e-Tough Guy Missouri City, TX 99 Contour SVT #143/2760 00 Corvette Coupe
#501126 12/14/02 10:41 PM
Thanks for the response! For the record, I'm running stock E1 wheels and the BAT Sport Kit.
#501127 12/15/02 01:24 AM
I almost forgot, if you DO load the trunk down with a lot of weight or get a couple of heavy passengers in the back, you may rub when going over dips, bumps, etc.
Since I hardly ever carry anything in the trunk and rarely have any passengers in the back, I've only rubbed once, and that was with a combination of the above (couple of 200lb.+ in the back along with some luggage going over a dip a little too fast). That was also with it lowered...
Otherwise, you should be in the clear!
#501128 12/15/02 01:44 AM
Alright cool, thanks! I rarely have anyone in the backseat of my car, and the only heavy thing that is ever in the trunk is my speaker box. Shouldn't have any problems then!
Moderated by  1314_dup1
