I live way down here in Mexico and am wondering if I can take my thermostat out permanently? It never gets below 45° here. Will there be some advantages to this? Thanks, John
'98 Contour LX V6 ATX
You know you're in trouble when your Grandma flips you off.
Yes,
The computer is programmed to deliver fuel at specific temperatures. If the engine is too cool, it will use more fuel.
Some put a lower temp thermostat in a car in an effort to squeeze a few more horsepower out of the engine.
But I wouldn't run without one for long.
TB
Tony Boner
MFE Offline
No, because without the restriction of the thermostat in the system the coolant may not spend enough time in the radiator to actually cool off properly...or so I'm told.
Pacific Green '96 Contour LX V6, loaded
'98 Grand Prix GTP 14.88/91 bone stock, awaiting new times from 3.4 pulley, CAI, U-bend removal but it's creeping up on the...
Calypso Green '92 Mustang LX coupe, 13.56/101
3-time local class champion autocrosser
Racing school whore
Actually, the thermostat keeps coolant in the engine until it reaches the temperature. If you remove the thermostat, the engine will run cool, you'll not get good heat. (not that that matters in Mexico)
FWIW,
TB
Tony Boner
E
E
Going off of what java was saying though. The engine needs to reach a certain temp before it goes out of open loop. If you are heating a couple of quarts of fluid this will happen much quicker. If you have to heat all 2+ gallons at the same time it will take awhile.
If I were to do anything, I would put in a colder thermostat, maybe a 180.
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
0
0
I agree.
The one in my SHO stuck open and the car never actually reached a proper operating temp. My mileage was poor, not that I really cared in that thing and power was a bit slugish. If the car keeps dumping more fuel than it really needs, there is a chance you may burn out your cats prematurely, because of the O2's running in open loop. That could be bad.
Don't try to go too cold with a thermostat, you may still run into problems down the road. A real cold thermostat is primarily used for a engine with lots-o-mods and high output.
You need to figure out what would fit your particular application the best.
Mark
00 svt tour- K/N filter, SHO SHOP Y pipe, 2 1/2" back to rear Y, improved tunes.
91 sho- Hi flow Y pipe, 2 1/2" exhaust, edlebrock rpm series 2 1/2" muffs, modified intake, K/N filter, modified manifold, 190 lph fuel pump, magnacor wires, ford double platinum plugs, underdrive pullies, custom LPM, 8 pound aluminum flywheel, hi revs race duel diaphragm kevlar clutch, solid torque limiters, poly bushings evrywhere, heavy duty subframe bushings, heavy duty engine and trans mounts, subframe connectors, front and rear strut tower braces, eibach springs, tokico struts, camber ajustment plates, light weight swaybar end links, cross drilled rotors, carbon fiber pads, 225/55/16 SP 5000's, redline water weter, redline trans fluid, mobil 1 synthetic oil, police grill and the need for speed!!!
It's a chronic disease.
I can see straighter now. Going to leave it "as is" Thanks for the responses. John
