Posts: 30 |
When you open the trunk on my 96 mystique it always has some water to drop on the contents in the trunk. What should I look at first to try and fix this?
1998 Contour SE
MTX v6 loaded
1996 Mystique GS
ATX 4 cyl
Posts: 1,459 |
My 95 mystique does the same thing. All I can figure is that the water is getting into the trunk lid from around the license plate light fixture.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 1,806 |
Mine does the same not sure what causes it though.  Mine only does it when the car was just washed or when it has rained.
Adam
Electric Red
95 Ford Contour GL
ATX Zetec
Born on 11/01/94
(The Official SCCEG Beater.)
Coming soon... Micah's Pre98 SVT Front Bumper and SVT body kit.
**1BADTOUR**
Posts: 463 |
This is a common problem as you already know. When you open the trunk after a rain or wash, look at the sockets for the license plate lamps. You will probably see the water coming from them. You have to remove the bracket, lens/reflector assembly from the trunk lid and reseal it with silicon. You could try and replace the gasket, but its probably going to start leaking again. While you are at it, remove the taillight lenses and reseal them.
I have seen lots of posts on this over the years and I know that other places do leak. These are the places that I had to fix on my 98 Mys.
jeff
have you fixed your ford lately?
Posts: 1,806 |
Originally posted by mercman: This is a common problem as you already know. When you open the trunk after a rain or wash, look at the sockets for the license plate lamps. You will probably see the water coming from them. You have to remove the bracket, lens/reflector assembly from the trunk lid and reseal it with silicon. You could try and replace the gasket, but its probably going to start leaking again. While you are at it, remove the taillight lenses and reseal them.
jeff
Thanks I'll try that and see if it doesn't fix my problem.
Adam
Electric Red
95 Ford Contour GL
ATX Zetec
Born on 11/01/94
**1BADTOUR**
Posts: 30 |
1998 Contour SE
MTX v6 loaded
1996 Mystique GS
ATX 4 cyl
Posts: 1,110 |
I thought that was normal?  Maybe not what I am thinking of. When I open my lid(with factory spoiler) when it is wet a little water always drips from the lid into the trunk(because it is over the inside of the trunk).
'01 Escape XLT V6 on S100
CDT Audio/Ascendant Audio/Rockford/JBL/Knukonceptz setup
'00 SE Sport ATX
Posts: 8,301 |
Originally posted by 2G Sport: I thought that was normal? Maybe not what I am thinking of. When I open my lid(with factory spoiler) when it is wet a little water always drips from the lid into the trunk(because it is over the inside of the trunk).
Thats what I thought, too.
-Ken V.
psycho_bass@hotmail.com
Posts: 21,653 |
i think they're talking about leaking inside the trunk not into it. leaking through gasket and into trunk even while closed, just opening to see it. though of course water drips in when it's raining and you open the trunk.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 8,301 |
Originally posted by Kremithefrog: i think they're talking about leaking inside the trunk not into it. leaking through gasket and into trunk even while closed, just opening to see it. though of course water drips in when it's raining and you open the trunk.
Oh, ok. I dont have that problem...yet
-Ken V.
