#499740 12/12/02 05:37 PM
can i remove the engine thru the top. or is the only way from the underneath.
#499741 12/12/02 06:03 PM
2
If you have a engine/transmission and a car lift, you can drop it from the bottom. But otherwise, you have to pull it from the top together.
Irfan Rahim irfman2000@yahoo.com 2006 Blue Nissan Sentra SE-R Spec V Former owner of a silver 2000 Contour SE Sport ATX
#499742 12/12/02 08:38 PM
Yes you can remove the engine from the top.
#499743 12/16/02 03:52 PM
if i remove the engine and tran thru the top. how do i get the tran. past the brake master cylinder and the battery holder which appears the be welded to the inner-finder. can i seperate the engine from the tran,so that i only need to pull the engine out of the car.
