Posts: 1,247 |
Anybody that did the throttle hang fix, did you have any cold starting problems?
Irfan Rahim
irfman2000@yahoo.com
2006 Blue Nissan Sentra SE-R Spec V
Former owner of a silver 2000 Contour SE Sport ATX
Posts: 118 |
Never had any problems, but for the first time today (very cold morning, I'm in Texas so cold is like 35 degrees F) the car didn't start as usual in a timly manner. I had to try and start it twice. It fired up the second time. I figured it was a combination of the TH fix and the cold weather. But no other problems other than that one time (so far)
1995 Contour LX (ATX)
KKM True Rev Sport Induction ( Video )
Alpine CDA-7894 / JBL 1200W AMP
12" MTX Subs 5x7 Alpine Mids
Brullen mandrel bent quasi-dual exaust
Posts: 2,408 |
 Exactly why do you have TH fix on an ATX ???
Posts: 1,110 |
Originally posted by Rogerm60: Exactly why do you have TH fix on an ATX ???
I had the moosing problem, solved with TH fix. And yes, it is an automatic.
'01 Escape XLT V6 on S100
CDT Audio/Ascendant Audio/Rockford/JBL/Knukonceptz setup
'00 SE Sport ATX
Posts: 1,247 |
Hey 2G. Are you still coming to the meet at Summit racing in Akron?
Irfan Rahim
Posts: 9,602 |
Originally posted by fordcontoursport: Anybody that did the throttle hang fix, did you have any cold starting problems?
If you use a hole too small the car will have problems holding an idle when it gets really cold. The hole I used is under 1/4" and as soon as the weather dropped below 40 degrees I started getting this problem. It only lasts for about 30 seconds & I'm not about to get the TH back so. I've just learned to work around it - 30 seconds is my minimum warm up time anyway so I'm not going anywhere anyways.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 118 |
So why do you think its not suppoesed to be done on an ATX? It fixed my TH.
Posts: 38 |
Hey, has anyone tried a slightly larger hole for cold weather? As easy and cheap is this mod is, is would be worth doing in a couple different sizes if it would help. Then just change as the season dictates--part of normal maintenance. Whaddya think?
Posts: 1,960 |
Thats the idea, you mess with it till you find what works for you. We all live all over the country, different air temps, humidity etc. The suggested diameters are just that, suggestions.
Good luck ....
Bless our servicemen & women overseas.
L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
Posts: 2,408 |
Originally posted by Jediboy: Originally posted by Rogerm60: Exactly why do you have TH fix on an ATX ???
Moosing I can understand, but I never had throttle hang on my ATX. Well that's not entirely true - but when I did have a problem it was the UIM gasket. New one fixed it right up.
