Posts: 76 |
I use a hydro zetec in a RWD platform. The stock single piece steel manifold shrouds about 20% of the bottom of the port in the header flange. I realise that most of the flow is in the upper reion of the exhaust port. Is there is "big bore" gasket for any Zetec available in the aftermarket? The standard piece will have compromised sealing if modified. TIA.
Posts: 2,408 |
Originally posted by se7en: I use a hydro zetec in a RWD platform.
??????????????????????????????????????????????????????????????????? Might get a better response if you explain!  Muffler shop can weld on a different flange, any setup you want.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 8,301 |
Call me crazy, is this for a kit car with a Zetec? Last time I checked, my Contour was not RWD
-Ken V.
psycho_bass@hotmail.com
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by CRZYDRVR: Originally posted by se7en: I use a hydro zetec in a RWD platform.
I wish it was. I probably could do crazy burnouts.
Hector
257HP/259TQ
160HP/141TQ
Posts: 8,301 |
-Ken V.
Posts: 3,465 |
ummm it's for his Lotus Seven hence the name... and also I'm unaware of any aftermarket exaust gasket manifold.
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
Posts: 76 |
Ayup. 96 contour block and management into a seven clone. 1450 lb with driver.  . So what do you guys with aftermarket headers use then? What do the Focus people use? I realise that the contique platform seems to be underrepresented in the aftermarket.
Posts: 21,653 |
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,465 |
aka ZetecRacing
