Posts: 37 |
I have a 95 SE V6 and my oil pan gasket is leaking. Does anyone know how hard itis to change it???
Thanks, Pete
Posts: 4,042 |
Fairly easy. You'll have to drop down the Y-pipe, and it's pretty much straight forward from then on.
John
Posts: 37 |
My car is a ATX would it be the removal of the pan be the same as a MTX???
Pete
Posts: 3,419 |
According to my brand new service CD, the ATX requires the removal of the Flywheel Access Cover, a small plate that looks extremely easy to rempve. Otherwise, it is the same as MTX.
Posts: 1,619 |
Originally posted by PA 3L SVT: According to my brand new service CD, the ATX requires the removal of the Flywheel Access Cover, a small plate that looks extremely easy to rempve. Otherwise, it is the same as MTX. Where did you get that service CD??? Tell me...Tell me!!!!! If it's a secret..PM me!! I won't tell...I swear!!!
95 Mystique LS Young America edition, V6, MTX, Yeah...it's stock. Now with new underhood wiring!!! My Profile Moderator of the Florida Contour Enthusiast Group
Posts: 37 |
How long does the cd say it take to do it?? do i have to drop the sub-frame???
Pete
Posts: 860 |
No removal of the subframs necessary. Just the pipe, flywheel cover, and oil pan. That's it.
Posts: 1,861 |
Are you sure that the oil pan gasket is leaking? There have been many mistaken cases that was really just oil spilled from changing the oil filter. Sometimes the oil will run along the seam of the oil pan flange as well as the slightly higher crank support girdle. The spilled oil will run across the front of the engine before dropping down near the front crank seal and the back edge of the pan. I have had several that only needed to have the spilled oil carefully washed off.
Jim Johnson 98 SVT
Posts: 3,419 |
Originally posted by MystiqueSVT:
Where did you get that service CD??? Tell me...Tell me!!!!! If it's a secret..PM me!! I won't tell...I swear!!! I just bought one off Bill Jenkins. Look in the classifieds, there is a guy selling burned copies for like $6.
