My stage 2 locks on the rear driver's door stick when the temperature drops below -15C. I know stage 1 is strong enough to hold the door closed but I'm not comfortable having passengers with the locks not working properly. The lock works perfectly fine if its warmer than -15C. I have tried spraying WD40 into the lock but it doesn't work.
Anyone have any suggestions? Is it easy to replace?
Thanks.
Edit: Found a similar post. Would Orange Cleaner work or should I use Gunk Engine cleaner?
