#51625 01/15/02 05:33 PM
cj95gl Offline OP
I finally got around to getting the readings for my check engine light. I know that I have a EGR problem but thought I also hadd an O2 sensor going bad. I was surprised by all the codes. Anyone know what all these mean?
Hard codes:53, 95, 39
Memory codes:11, 73, 32
thanks in advance,
Chris
95 GL V6 MTX, KKM, SVT springs,struts, exhaust, CELs
#51626 01/15/02 09:42 PM
Are you sure those are the codes? If you rearrange the commas, you'll get some good codes:
Hard: 539, 539
Memory: 117, 332
539 is Air Conditioning switched on during test
117 is Coolant temperature sensor- normal operating temperature not reached (run the engine until it's fully warm and this should go away. otherwise, just change it)
332 is EGR valve not opening
Get a Haynes manual if you can. It has this in it. smile
96 Green Mystique
Zetec
ATX
No mods yet (wife's car but I drive it all the time)
"If you want something done right, do it yourself or use an SAE mechanic you can buy beer for."
Ricers are like the mosquito that buzzes in your ear but you can't kill. They just won't go away.
#51627 01/15/02 11:17 PM
cj95gl Offline OP
thanks,
I'll check out the haynes manual. I thought they should be 3 digits but it sure seemed like the timing was for 2 digits.
