Posts: 21,653 |
Originally posted by ZetecRacing: mine don't tick... ooh and every other responce in this thread was about the timing belt making noise....
have you put your ear right next to them? you may be use to it,,, if they don't tick then you have an abnormal engine.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 3,465 |
2003 Subaru WRX some mods
Even if you don't have the answer, you certainly have to admire the problem.
aka ZetecRacing
CEG road warrior
CEG road warrior
Posts: 17,248 |
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 974 |
The ticking is normal both for the valve train and the injectors. Unfortunately, the Zetec engine makes more noise than others. You will notice this especially when you start the car for the first time and especially in the cooler weather. Make sure to keep up with your oil changes too especially during the cooler months and it wouldn't be a bad idea to let the car warm up some before you drive it.
Just be careful with your cars especially now when the months are cooler as your oil in the engine will be thicker and won't flow as good as if it were warmer.
L8R Kids Rich
'04 Ecotec Cavi 140hp/150tq Fabbed intake. Header Coming, DRL's disabled, X-Drilled/slotted rotors coming....Man you really are fast. You were hauling a$$ when I passed you
RB&LB
causing problems in Huntsville
Posts: 21,653 |
i live in georgia, so car will probably always getting started in over 25 degree F temp. and it's mobil1, so shouldn't have to worry about oil being thick. i let it idle down and wait a few more seconds and go, unless i can't see through the frost of course.
98.5 SVT
Posts: 569 |
Originally posted by sesomba: FOUND OUT IT WAS THE IDLER PULLEY AND TENSIONER PULLEYS THAT WERE MAKING THE NOISE.
I had the odd bumping sound comming from the passenger side. Pulled the upper timing cover and found my timing belt chewed up on one side and the belt was riding on the edge. Ford found the idler and tensioner to be faulty. the car had uper 20's to lower 30thousand miles on it. So Ford fixed it under warranty cause the pullys were bad.
....Brad
Your mom thinks I'm hot!! But my wife rocks!!
99 Mestique Zetec ATX, 96 4Runner 5speed
Mods? Um gotem.
VFA-94VFA-122 VFA-115
Posts: 21,653 |
i took top timing belt cover off today, belt is in perfect condition but it is pretty close to the edge. should i be worried? me drive belt pulleys squeak though. i thought it was the idler pulley, but when i sprayed belt dressing on pulleys the squeal went away when i hit the tensioner. So do I just need to replace the tensioner? Is there a way to tell if the idler pulley is bad? and any specific way to replace the idler pulley? (haynes manual has nothing about it) thanks in advance.
98.5 SVT
Posts: 79 |
Could any of this make a engine not able to produce a lot of power? My timing belt is 76k miles old and I can slide it along the cam gears with somewhat ease...Is this a bad thing or what?
Posts: 21,653 |
you can slide your timing belt?  definitely replace it, it has little things that should go into the grooves and shouldn't be able to be moved like that, unless it's real lose. i'm sure it can't help that it's loose for making power.
98.5 SVT
Posts: 79 |
Not over the grooves, but laterally along within the grooves
