Occasionally my clutch pedal will get soft. It still functions the same then after a few minutes it goes back to normal (not hard but not soft). Any ideas would be helpful.
I suspect that you have some air in the hydraulic system. Bleed it real good, more than once if necessary. Make sure that you keep the master cylinder full so that you don't add more air while trying to solve the problem.
