Ok by the Ac knobs I am trying to change the glow of the letters and pics to a blue. I have got it all apart and found out that replacing the bulbs with blue leds will not help. I was told to scrape the green off the back of the black piece and repaint it with a light blue. I got the black piec off but it is still connected to the plastic backing piece. IT is glued or something. How do I seperate them pieces without destroying anything. I was told to boil em or use a blow dryer to them. Is this correct and which method is safer/better? Thx for time and help.
V
V
Hmm, I'm trying to get the panel out so I can change a blown bulb back there, but I can't for the life of it figure how to get the plastic trim off..Any pointers?
Midnight Red '95 Contour SE. YoDude quasi-dual cat-back w/ Dynomax muffler. SVT UIM and TB. KKM True-Rev CAI. Pre-98 SVT front and SVT rear conversion, YEAH BABY! Alpha Kappa Psi
well in my 97 mystique i just noticed thiers two bulbs but i doubt that helped you any becuase you most likely own a contour.. note i havent tried it. I only noticed it when changinga fried ac blower switch
97 Mystquie GS - I4 ATX died at 168K 94 Pontiac Crap AM SE - 2.3L I4 5spd 2002 Mazda Protege5 - 2.0L ATX
H
H
me neither<Hmm, I'm trying to get the panel out so I can change a blown bulb back there, but I can't for the life of it figure how to get the plastic trim off..Any pointers?>
I got mine out, but I did not notive a screw, on a +98 contour there are 4 screws to get that panel off, probably similar for the others. All of the screws are on the bottom area, I had to remove the front most part of the center console to get to two of them. I hope that this helps, now I am off to the dealership to order the part I broke
1998 T-Red SVT Contour #2588 of 6535 2005 F-150
