Page 2 of 3 1 2 3
its the motor mounts,us at the dealer replace them all the time for the same problem
Kenny are you refferring to the upper or lower mounts or all. I'm having the same problem, I replaced the lower F/R motor mounts and it's still there, the vibration that is. Does it when idling, settling to idle and around or up to 1100-1200rpm.
I actually hope its the motor mounts and not something trans/engine related....
Performance Xpress Racing
Silverbulitt@msn.com
Our websit www.PXRacing.com is coming soon!!
We carry Contour/Cougar parts for the 2.5 Duratech and 2.0 Zetec
Try your serpentine tensioner pulley I went through the same things you guys describe. 20 bucks a tha junk yard.... 3 bolts not to bad. Do a search I have a how to on how to check it to see if its the cause.
smile smile smile smile
96 teal contour
nothing yet but im saving
If you can isolate which panel it is, try to remove it, put vaseline on the mounting point, and re-attaching it. But be warned -- removing the panel might make it worse!
Try ****ing into neutral, it helps on my 95 when it rattles.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
JJC Offline OP
I will check it all out.... and post what it was, if we can find it.
thanks
as for the vasaline, no thanks
N
N
I had the tensioner replaced on my 95gl and it cut down on the rattles alot. (mine does/did it also) My mechanic told me it may be motor mounts that tend to be bad on alot of contour/tiques, but the thing about the torque converter being locked up, I would disregard that as a problem... Whatever causes it is something that should be able to be fixed at a fairly low cost. It just depends if you can live with a little vibration or not, mine is so small now its not even worth it (to me) to fix.
1996 Contour
New amp rack and custom box
pics coming soon
"When im good, im really good, but when Im bad, Im even better"
key Offline
I have the same problem with the heat and air on or off. It also does that if i am in park also ..i hate this car
kp
I just realized what your problem is.
Someone else tried this and posted about it.
If the subframe goes out of line, you get the vibrations that you guys are describing.
You need to bring your car to a dealer and get a DRIVETRAIN ALIGNMENT.
This is different than a Wheel Alignment.
If just one of your engine/transaxle mounts are out of line with the subframe, then you get all kinds of noises, rattles, and vibrations.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
E
E
I don't know if it is so much that (drivetrain alignment). IMHO, Having the drivetrain out of alignment would cause them once you got up to speed. My `96 does it at idle, but it comes back to the way the engine is running (poorly). It has some new spark plug wires coming for it (misfire problem) but right now the idle is slightly erratic.
I'll bookmark this thread and reply after the new wires go on. smile
Only at idle, in gear worse then out of gear, the more accessories that are on the worse it is. Right? That's what mine does. frown
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
Customer Satisfaction Program Number 01B78,
Replaces dash board for 99-00 Contour/Mystique
Dash is noticibely loose and vibrates especially around defrost vents. Maybe woth checking out for your vehicle.
99 SE Contour,V6, MTX
MODS
KKM,Res rmvd
Fog light fix
Throttle Hang fix
Panasonic CD head unit
4/ Sony X plode 6x9
Jensen 300w amp
Page 2 of 3 1 2 3
