The car has the auto trans. Here's where I'm at on this darn project. I have the serpentine belt off, the valve cover off, and I have the cams locked with a flat bar at TDC.I can't get the crankshaft pully off, the Haynes manual says take the starter off and wedge a screwdriver in the gears. Since I didn't want to take the time to take off the starter, I tried just loosening thecrankshaft pully using the resistance from the flat bar locked in the cams, that was a mistake, I must have stripped out some keys in the gears that turn the cam shaft. Fortunately, I did mark the cams and crankshaft pully posistion with a marker prior to this stunt, so with a little luck I should be able to get everything aligned again eventually. But back to the real issue, any tips on getting the pully off? Thanks!
