Posts: 7 |
Am I the only one with this problem? I have replaced my wipers four times in the last 1,000 miles. I tried Lexor, Pylon, Bosch and currently have Anco blades. I even scoured the windshield with Bon Ami, as suggested by the wiper manufacturers, thinking that a previous owner may have used some "mystery chemical" on the glass. I have tried several "mystery chemicals" myself, scouring well between each one; nothing has worked! The only time the streaking is evident is when there is overhead lighting, such as street-lights, etc. Streaking is not evident when driving in total darkness. Streaking is even bad when driving in the daylight if the sun is shining through the rain. Even though my windshield is not excessively pockmarked, I am seriously considering replacement. I haven't because it may be the angle of the windshield and I would still have the problem. Any suggestions? I am ready to try almost anything!
John
Black '98 CSVT
#2000 of 6535
Sometimes good, sometimes bad
Sometimes hate it, mostly love it
No mods other than 215/50ZR17 tires
Posts: 644 |
I'm assuming you've cleaned the inside, too, right?
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 1,881 |
Originally posted by delmar: I'm assuming you've cleaned the inside, too, right?
Yeah, a clean inside is key. Maybe someone oversprayed Armor All on the inside of the windshield.
1998 T-Red SVT #957
Born 5/14/1997
Posts: 7 |
The inside is spotless! All the streaks are on the outside and follow the trail of the wipers. When operating the wipers on intermitent, the streaks disappear in a matter of seconds only to appear again following the next swipe of the wipers.
John
Black '98 CSVT
#2000 of 6535
Posts: 970 |
I got that too. In my case it was oil mist from when I got the car undersprayed. Nasty stuff. Squeegee at gas station didn't help at all. Went to a do it yourself wash and turned the foam brush on it. Lift the wiper blades and foam brush them too get get at the oil.
All good now.
98 GL sport (V6 MTX)
The Durable Duratec? - (DMD, Metal impeller WaterPump, Synth & Stinky in the tranny)
Posts: 195 |
Might be a long shot but when my wipers wern't working too well I very slightly bent the arm inward, (towards the glass) which put more pressure between the blade/windshield contact.
1998 ContourLX V6 ATX
Cats Gutted+MIL Eliminators
Grandma gave me the finger
Posts: 163 |
I have permanent streaks on the outside etched in the glass (from the wipers). Its really annoying when the sun hits the winshield in the scratched part.
2003 Hyundai Tiburon GT 6-speed Black
-former owner of a 1999 Navy SE Sport ATX
Posts: 89 |
Sounds like you're ready for windshield replacement.
The only other way to remove ground in scratches in a windshield I know about is to use a glass polishing kit which involves fine abrasives & lots of time with results unspecified.....my $.02
Is the smoke alarm in your house also known as the dinner bell?
'99 Zetec VCT Daily Driver
Mild Air Filter Mod
Posts: 3,110 |
clean the class with Stoner's invisible glass or even better, white vinegar mixed with water.
it removes any water spots or streaks that may be on your windshield. I too went through the same situation with blades and that water/vinegar mix worked well in getting the issue resolved.
Hugo
98 SVT - 53k mi - SOLD
04 Mazda3 S 5-Dr
Posts: 157 |
I find just polishing with regular car (paintwork) polish usually does the trick. Not the cutting type though - maybe someone before you used that........
