#489531 11/27/02 08:17 AM
im trying to figure this out i have normal power from 0 to 3400 RPM but after that it pulls like a honda which bothers the hell out of me i have some of my own ideas as to why it is doing that but i thought i would ask some of the more experienced guys what you guys think
thanks
peter
SHO Y pipe, Fredenza fly, Unorthodox clutch, UN pulleys
#489532 11/27/02 08:49 AM
N
N
Those extra 12 valves could be getting stuck due to contaminated oil, or wrong oil, I think the early owners books stated 10/40 and you should only use 5/40 5/30.
Neil
um I cold be totally wrong, and probably are.
Mondeo (UK Model) GhiaX 2.5 v6 DMD 2003 Version GhiaX 2000 Spec Semi Automatic Climate Control Power Folding Mirrors, Japan Stylie Ford OEM RSAP Latest Sump Revision
#489533 11/27/02 08:57 AM
~3400rpm is the point that your secondaries should open. If you are losing power, then they are probably stuck clsed or not opening as much as they should.
I dug around in the archives and the possible causes are : bad imrc or a fuel pump on the way out.
HTH ....
Bless our servicemen & women overseas. L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
#489534 11/27/02 08:58 AM
Sounds like your secondaries might not be opening.
-Ken V. 1998.5 SE Praire Tan Zetec ATX psycho_bass@hotmail.com Roush springs Roush rear sway bar BAT struts 17" Millie Miglia HT3 and a ton of subtle asthetic mods
#489535 11/27/02 09:21 AM
thanks for everyones help i kinda figured it was the secondaries i thought it might be fuel related but what exactly is the imcr... i cant remember
thanks
peter
#489536 11/28/02 12:14 AM
AFAIK, that is what controls the secondaries.
#489537 11/28/02 12:25 AM
thanks
peter
Hi Peter,
imrc, Intake manifold runner control
It is the silver box under the duratec plastic cover at the front of your car.
If it is stuck closed it will give you a code, but NOT a CEL, anyway you should check for codes for free before do anything else,
RMR
1998 Contour V6 2.5L ATX
