#489376 11/27/02 04:57 AM
W
whitegt Offline OP
W
I have a loud humming noise coming from under my hood. It only happens under cold startups and when I turn on the heater. I have taken it to Tommie Vaughn Ford for warranty and they installed a new tensioner pully. And the noise came back this morning. So I am taking it back in the morning but I was just wondering if anyone had any ideas or has experienced this problem before. Thanks for any help
-whitelx
2000 Tropic Green SVT Contour Back to stock.....? 1991 Mustang GT Oxford white Lots 'O Mods awaiting P1-SC this summer
It sounds like it could be what is commonly called "moosing".
Check the following:
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=15
My 99 SE Sport has similar problem. The idle seems to be going fast when "moosing". Does yours like this?
Thanks.
