Originally posted by natesvt: a couple times i tried to start my car and both times it didnt start i had to jump my car. my battery was tested and is perfect so i cleaned the terminals and it works a lil better. the other day i was drving doing about 40 and my car shut off and i rolled to a stop. the check engine light went on along with my battery light. it sucked. but i turned the key just for the hell of it and it started up no problem. what the hell is that about. it shut off once before this but it was right after i jumped it so i didnt think much of it at that time. it also started right up after that time too. how do i fix that?
Did this happen while it was raining? This has happened on my car while driving through a big puddle recently. If it wasn't raining, then my guess would be a short somewhere. Check all of your wiring. You can do also try wiggle test while the engine is running: grab each wire and wiggle it gently. If there is a short, then it should stall the car when you wiggle the bad wire. Just be careful of moving parts
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
