#488472 11/26/02 01:28 AM
My Mystique 1995 with 2.0 engine idles perfectly at/or about 900rpm. When I shift to drive, the rpm drops closer to 500 giving a rough idle. I just noticed my other car with a GM 2.4L engine also idles at 900rpm and stays there when I shift to drive. Any ideas on my Mystique problem?
#488473 11/26/02 02:22 AM
If it idles high when started cold the IAC is working, but it may stick some. Vacuum leaks would be my first check. Check the PCV valve and hose and make sure the intake system is sealed tight.
#488474 11/26/02 09:24 PM
Roger: the Mystique does NOT idle high. It idles at 900rpm which is excellent but drops to 500 when shifted into drive. How do I get it to stay at 900rpm when in gear?
#488475 11/26/02 11:32 PM
If it does not idle high when started cold, that is a problem itself.
The IAC opens and closes to control idle speed. When first started cold, the engine should run 1500-2000 rpm. It should come down to 900 rpm within 30 seconds to a couple of minutes depending on temperature. This allows the engine and O2 sensors to warm up. If this happens, at least you know the IAC does move.
If the engine cannot adjust to the load of the torque converter in drive, it generally means that the engine is running lean. This can be caused by extra unmetered air getting into the engine through a vacuum leak or simply air bypassing the metering device (the mass air flow sensor).
Again, check the PCV valve and hoses in the PCV system. This includes the hoses from the valve covers back to the inlet tube. Also check that there are no possible leaks in between the throttle body and MAF.
If the engine seems to lack power in general, the MAF itself might be dirty and not measuring the air correctly.
Remember, the computer will adjust the idle speed only if it is able to control it (the IAC) and if it has the correct information to do so (MAF)
If the CEL has come on, check the codes first.
#488476 11/28/02 07:02 PM
How soon are you shifting into gear?
I used to have a problem with my old 2.0 also. If I didn't wait for a few seconds before shifting into gear my car would idle rough, almost stall. I had to learn to wait and then everything was fine.
I don't know if this helps. Just thought I would throw it in there.
Mike 1999 Tropic Green SE Sport Duratec MTX No major mods, just the aesthetic kind.
