Can anyone help me out here? I have a 97V6 that about 4 months ago my buddy changed out the thermostat and then the water pump.
The water pump's impelers blew apart. As if you guys haven't heard that one before
Any rate, he flushed the system, and the car is running fine. The temp is remaining in the same place it did before so I lucked out there...I heard of others having thier cars either running to hot or to cold. Mine stays on the "N" all the time except in trafic. Then it moves to the "O and R"...
OK, my issue because from here everything seems normal. OH yeah my heat is just fine as well..
MY coolant light comes on and off all the time. Its on when I start the car and in a half hour ride it comes on and off about twice...
The coolant resivoir is filled to the line where it should be?
Someone told me that there could be a sensor in the coolant tank that lets you know its low ever? Could that be bad or dirty? If so where is this sensor and can it be changed? Are the expensive?
Also has anyone ever gone thru this as well??
Thanks for your time. Have a great holiday this week...
Spankey
