Okay... here goes.
My car is a 2000 SVT, 40000 miles. I have a kkm on it and thats about it. I change the oil regularly. about 10000 miles ago I had a problem where the car would start but would not Idle. If I put my foot on the gas it would run, but thats it. I checked the throttle body and sure enough it was coked up. I cleaned it thouroughly and reinstalled. That fixed it. Now its back allready, also the car is hesitating. Bad. I figure the carbon build-up is caused by the EGR, thats the only thing I can think of. But what could be causing the hesitation. I just cleaned the Air filter. I will admit though that it still has the original fuel filter. could this be the problem. I would also like to know if I was to make an EGR block off valve, might this hurt the car?? thanks for any replies
One more thing... my brake pads are going... any suggestions on a good aftermarket pad to use. I was thinking either mintex or EBC greens. It just seems a shame to do all the work and use factory parts.
remove the IAC valve,check it for sticking and check its passages in the manifold re carbon/gunk buld up.......
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
N
N
wouldnt hurt to check your fuel filter
1996 Contour
New amp rack and custom box
pics coming soon
"When im good, im really good, but when Im bad, Im even better"
Aww, Comon Terry, you know that Ford has never had an issue with IAC valves sticking. :rolleyes:
Worst thing is, the culprits are probably in my building somewhere...
1999 Contour SE Sport MTX75 T-Red/Grey
Audio: Pioneer DEH-7400MP (MP3 CD), Pioneer TS-A6857 front & rear, PPI PCX-250, Infinity Perfect 10.1
Other: cup holders, cargo net, Blizzaks, Potenza RE950s
Also check your vaccum lines...I had the same problem where it wouldn't hold an idle and it hesitated and was idiling something aweful. I took it in to get it fixed and the cleaned the maf and replaced the vaccum line...my baby is all better now....just thought this might help with the diagnosis...
:p
Alicia
96 Contour LX
2.5L V6 Duratec
DOHC
Stock of course!
BAD ASS GIRLS DRIVE BAD ASS CARS!!!
