#486477 11/22/02 06:11 PM
karter Offline OP
I have read about the problems with some of the water pumps having the plastic impellers. My contour is a '99, did Ford solve their water pump problems by then? If mine has almost 50,000 miles on it should I just replace the old pump with a new one? Does someone make a better pump? I don't want to wait for a failure and then buy a new motor.
#486478 11/22/02 06:24 PM
Welcome to CEG
The water pump problem is with the V6's. I believe Napa sells the one with the metal impeller if your going to change it.
www.ChicagoCEG.com 2006 White Grand Prix
#486479 11/22/02 08:39 PM
On the V6, check the belt tensioner if you replace the waterpump, if it is rusted tight, it might lead to early pump failure.
