Posts: 344 |
Is anyone else experiencing brake fade during wet weather? This only happens occasionally and feels like I have no brakes at all but I have a full pedal though. All new disc set up about 4 months ago and just started noticing a problem. I am not losing any fluid. And of course the nit wits at Ford seem to be clueless. Hell I even put all new brake lines on the thing when I did the brakes. Talk about a pain in the arse job. Had to drop the friggin gastank.
95 V6 5SPD.
Shaved bumpers,antenna,trunk lock and 1/4 extensions
MIDNIGHT RED.
Posts: 13 |
I get that too. You didnt mention what kind of pads you have but I read that my pads (KVR carbon fibre) are affected by the wet weather.
Ground Control Coilovers
Koni Adjustable struts
Sub-frame connectors
Slotted rotors
Carbon Fibre pads
Stainless Steel Braided line
KKM Intake
Pro-Flow Mass-air Meter
22mm rear sway bar
Polyurethane motor mount inserts
Posts: 717 |
If you've got full pedal, it's just a case of the rotors and pads being really wet. Some pad/rotor combinations are worse than others. After I go through a big puddle or heavy rain, I keep a light foot on the brake for a short distance while driving to dry them out. That way, I have brakes when I need them.
contours, deloreans & fiats, oh my!
Posts: 344 |
Im running standard ford pads. Damn thing is I didnt have this problem with my old pads and have never had this problem with any other car.
95 V6 5SPD.
MIDNIGHT RED.
Posts: 319 |
Do i ever! It almost feels like no brakes at all. Very scary. My next set might be cross drilled rotors. We see a lot of rain here.
1998 Contour SE
Panasonic CQ-DFX683
Sound by Crystal Mobile & Illusion Audio
Powered by Alpine MRP-F240, Alpine MRP-M350
My Ride
Posts: 149 |
*warning* This is a wild ass guess-
Do you know for certain that your pads were bedded in properly? If not bedded in, the pads will not have the optimal interface with the rotor for maximum friction. This lack of friction could be exacerbated by the wet.
How long does it take for you to get your brakes back?
Now you know why they put the "Check your brakes" signs on the highway/tollway.
'99 Black SVT
Join the SVTOA
Posts: 344 |
I just pump and hold it for a few secs then everything is fine. But the first time scares the hell out of ya. I have done more brake jobs than I can count. It happens all to often in hard front end collisions that I work on. but this is the first time anything like this has come about.
95 V6 5SPD.
MIDNIGHT RED.
Posts: 319 |
Well i will be upgrading to the big brake kit from BAT soon and maybe this will help out.
If not just have to try to keep the some what dry and keep my distance.
1998 Contour SE
Panasonic CQ-DFX683
My Ride
Posts: 770 |
After changing pads several times on these cars I found they will not tolerate cheap pads. I tried Performance Friction, Raybestos, KVR, ACDelco HP and Mintex. The Mintex are the only ones that worked better than the OEMs that came with the cars. These so called long life, low dust pads suck when it comes to stopping power. Only other ones I would try are the EBC greenstuff.
Posts: 1,831 |
I experienced the same thing with my stock pads and discs after about 30,000 miles. I went to the KVR cross drilled rotors and carbon fibre pads hoping they would solve this problem. NOPE. The KVR's suck so bad in the rain that the problem is worse, even with the drilled rotors. I'll be going to Mintex A/F pads next spring.
Doug
2006 Mercury Milan V6 Premier Dark Blue Pearl
Former owner of a 2000 SVT Contour
