#51030 01/06/02 10:27 PM
H
H
I know these are probably asked all the time, but I am still getting used to my Contour.. so I am a newby, I guess... If ANYONE can provide me some insight, it would be greatly appreciated!
1. My CEL is on, and was told that it was the rear downstream O2 sensor, I replaced that (but the plug from the NAPA part was not exactly the same..) light has not gone off... now getting a rotten eggs smell. Can this still be from O2 sensors.. or am i definately dealing with a bad Cat??
2. Will the cat throw a check engine light?
3. Which should I change first??
4. How much am I looking at.. parts and labor, for the cat replacement?
5. Is there a process to reset the light to see if replacing the sensors does anything?
Sorry about all the questions, but I am new.
I am considering changing both sensors, then having dealer do Cat... any advice is welcome.
Thanks.
1997 Ford Contour Sport V6
Champagne
#51031 01/06/02 11:30 PM
Make sure you are doing the right sensor - bank #2 is actually the front of the engine bay, bank #1 is the side closest to the passenger compartment. Whoever gave you the code should have mentioned which bank the code came from.
Do you have the actual code? P#### format
Not having the same connector doesn't sound right to me. Are you absolutley sure you have the correct sensor?
You should reset the PCM (pull fuses #4 and 11 or neg battery cable) to clear the code. Especially if it is the rear O2 sensor - the Cat Monitor test runs VERY infrequently and the CEL won't go of until it does (and passes).
Cat replacement is big $$$ - you are replacing the exhaust manifold. Not cheap, and not a small job labor wise.
#51032 01/07/02 01:56 AM
There is a recall on the cats http://www.alldata.com/TSB/19/971941C8.html
you should call a dealer and see if your car has had it done or make a post in here asking for an oasis report.
98.5 SVT#6092 of 6535 B/MNB
Born on date 5/22/98
Y2K Suzuki GSXR 750 Y/B with 140.6HP
#51033 01/07/02 07:02 AM
Do dealers have record to show which recall had been done on my car ?I mean there is no hurt to replace the cats once in awhile.
