#51007 01/05/02 06:08 PM
Bill D Offline OP
My manual is a litttle vauge on how to remove the knob from the headlight switch prior to pulling the switch. I have popped off the part of the knob taht turns but it seems there is more below that has to come off.
Bil lD.
PS this is because I weant to change to a foglight able switch. I am hoping to get one from a Tarus to fit?
i think you'll have to take the trim panel off that covers the steering shaft (below the steering column). That's 4 bolts...
Then 2 screws to get the panel that the switch is attached to off.
From there you can remove the switch (attached by 3 phillip screws.).
These are instructions off my '99 SVT. Good luck.
Black '99 Contour SVT.
Stereo Upgrades & Cosmetic Enhancements
...Always clean, Always mean.
Works for both the Tour and Mystique. I think the socket for the bolts is a 7 mil if I remember right.
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
