I wonder if different years/models have different amounts of room along that back wall. All I had to do is undo one clip on the distributer and I was able to get to everything just fine. I have a 96 SE, maybe the SVT is different.
Also, don't forget: - Dielectric gel. - Torque the spark plugs to the proper rating, being a farmer here could set you up for some problems later. - The forum seems to be split on anti-seize, I don't use it myself (just to darn lazy) and everything works fine for me. - Don't get dirt or other junk in those holes
I do have a question myself though, my Haynes manual says the torque rating is 84 to 180 in-lbs. That seems a bit vague to me. I used 120 and everything is holding together just fine but does anyone have a better number to use?
Scott 96 SE, MTX, BAT 22mm rear anti-sway bar, BAT springs and Spax struts 96 Caprice, 9C1 Rayon is made of wood!!!
