Posts: 14 |
I am going to change my plugs in my 95 gl and I want to know how hard it is to change the back plugs in it ? thanks!
95 contour gl 2.5 v6 p.o.s. car (LOL)
Posts: 291 |
Have a mechanic do it. The back cylinder bank is almost against the firewall and without a lot of complex tools (the kind that form elbows and the like) it's not worth it.....
Posts: 59 |
It's not too hard to do, I did it in less then 1 hour, 6 plugs and ford motorsport 8 mm wires. To get the ones in the rear i first took a spark plug rachet head (it is a deepwell with a piece of rubber on the inside to grip the end of the plug to help pull it out)and attach a 6 in extention and slid them into the plug hole. Then i attached a 2 in extension to that along with the wrachet. Loosen the plug with the wrachet untill you can spin it by hand. to remove, disconect the 2 in ext from the 6 in ext, then pull the 6 rest out. If that dosen't help try this link.http://www.contour.org/mods/mods.cgi?s=howto&display=plugs
91 Honda CRX Bilstein shocks, Tenzo R springs 96 Ford Contour LX V6 ATX KKM intake, Ford Motorsport 9mm wires All Kenwod Stereo System - 134db KDC-8016 headunit, KAC-859 amp, KSC-BP210 bandpass, DualMags: 6.5" front and 5.5" rear
Posts: 1,537 |
MRCRXTRA is right.
I also did my plugs the same way, and it is very easy. I installed Platinum +4s, and Blue FordMotorsport 9MM wires.
Just make sure that you change the plugs on a COLD engine. We have aluminun heads, and it is easier on a Cold Engine.
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Posts: 477 |
Easy. hey, if I can do it, then anyone can do it (I don't have experience working on cars, other than the mods you see below). I changed my plugs in about an hour tops. I did have to remove the distributor box to get in there, but it comes off with 4 bolts. I didn't have any major problems. Use the tools that MRCRXTRA mentioned (the 6" extension and the spark plug rachet head). Good luck!
1996 Contour SE Red V6 MTX 1995 Contour LX Champaign V6 ATX (my wife's beater) SuperChip | KKM Intake | Ford Motorsport 9mm Wires | Bosch +4's | Mobil 1 | No Resonator | Knauberized Doors | JSP Custom Wing | Re-wired Fogs | Red Painted Calipers | 98+ Sail Panels | Vuncannon Alarm | Lighted Moonroof Switch | Pioneer Head-unit | Pioneer 6x8's
Posts: 4,319 |
1991 GVR4 Lots of mods done.
Posts: 233 |
does anything else have to be removed...my car is approachin 30 k and thats when i wanted to change the plugs and wires. i just want to be informed before i jump in head first
-Y2K SVT- BORN 1/03/2000 NOW IF ONLY HAD MONEY TO MOD IT
Posts: 1,537 |
Y2K-SVT,
If you've only got 30K miles I wouldn't even bother, with the plugs and wires. I changed mine at 60K.
But @ 30K miles, the Cabin Air Filter, and your Fuel Filter, should be changed.
Posts: 7,329 |
Exactly... There is a wealth of information already on the main site. Took me about 1 hour to do plugs & wires and I was being very detail oriented... Simple job with a metric socket set.
Posts: 345 |
Originally posted by NateCox: Have a mechanic do it. The back cylinder bank is almost against the firewall and without a lot of complex tools (the kind that form elbows and the like) it's not worth it..... You've got to be kidding me. I must be pretty special. I did mine with a regular socket set and an extension.
Pacific Green '96 Contour LX V6, loaded '98 Grand Prix GTP 14.88/91 bone stock, awaiting new times from 3.4 pulley, CAI, U-bend removal but it's creeping up on the... Calypso Green '92 Mustang LX coupe, 13.56/101
3-time local class champion autocrosser
Racing school whore
