i would like everyone to reply that knows the answer even if its been said. WHERE DO YOU SPLICE THE RPM WIRE INTO BEHIND THE TACH.? i tryed the white wire with the black stripe in located in the middle of the tach harness and the shiftlight comes on before the tach. reachs the dial set rpm. and yes i did cut the loop to calibrate it for v6 PLEASE HELP
