Posts: 21,653 |
I think my atx may already have some problems, when i was dumb, i tried neutral dropping it and it just shuttered and didn't move. i was wanting to switch to mobil1 syn atf, but with 86k+ miles and possible problems, is this a bad idea? what should i do? and if mobil1 atf is still a good thing to use, where can i get it? (haven't been able to find it).
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 2,408 |
 Did you learn anything? The neutral drop is kinda like beating it with a sledge hammer, huh.
Posts: 9,442 |
N  eutral drops are kewl...Do it again, do it again!!!
Posts: 64 |
Posts: 2,408 |
Originally posted by Tribal: Ported and Polished my Intake and bored the throttle body and my MAF sensor
 You got like a how-to for boring the MAF?
Posts: 64 |
I dont really bore it straight through if that was what you were thinking  I use a small honing bit on a drill and run it inside the front bore and rear bore of the maf sensor untill the side walls are about a 16th of an inch thick. Then I dremel all of the edges of the maf sensor tower in the middle to make it as small as possible so more air can travel through the center. Then I take out the maf sensor it self and use a straight boring bit in a dremel and bore out the maf sensor air tunnel where the sensor sits in and chamfer the edges. Then I use a wire brush bit and polish the inside of the maf sensor and the air tunnel, put the sensor back in and presto  I have a bigger maf sensor which kinda made my gas mileage worse because the engine now uses a little more fuel with the larger amount of air that is traveling through. But it helped the throttle response quite a lot and I can feel more pull at higher speeds.  Sorry for the long explanation.
Posts: 21,653 |
thanks for the info on killing my atx even more and on modding a duratec.... now any answers to my questions in my first post?
98.5 SVT
Posts: 5,854 |
Sure, dont' do anymore neutral drops. If you did break something, you're not going to be able to fix it with a fluid change. Though it wouldn't be a bad idea to change the fluid. As far as "boring out the maf" it's cool you're that handy with the dremel, but it's a stupid idea to do that. You can seriously screw with your car's AF and possibly do damage to the motor. The maf looks the way it does for a reason
1999 Silver Frost SVT
#609 of 2760
Posts: 21,653 |
my question is, can i safely switch to mobil1 synthetic and where can i get it? or is there something better for high mileage/wear tranny?
98.5 SVT
Posts: 2,241 |
from what i've read with the cd4e's you're no better off with synethic over the standard mircon
-Matt
"Pain heals, chicks dig scars, and glory lasts forever!"
will do/pay just about anything for the following parts:
CF sunroof glass replacement
OEM CF trunk
Non OEM style cf or fiberglass hood not the cf1 design
