#50809 01/02/02 10:22 PM
sinned Offline OP
in new york it's about 20 degrees, when i take off in the morning to work i don't have time to warm the engine. Is this normal for the car's idle to drop to where it want's to shut off? if so do i leave it alone and let the computer take care of it or do i drop it into nutral and depress the accelorator? Is this a larger issue or do i just warm up the car instead? Any infor is welcome.
1995 Contour SE
champaign
#50810 01/02/02 11:54 PM
E
E
your idle motor might be shot id pull the fuses(4 and 11) for 5 mins put them back in then let the car idle till the fan comes on...
check the MAF sensor sometimes a shot of carb cleaner works but once again reset the comp after that
oh yea make sure u pull the fuses in the engine bay!
_Eric_
95' Performance White Contour Gl Zetec ATX
-A beautiful girlfriend next to me...what other mod is important?
#50811 01/03/02 02:54 AM
you mentioned the maf sensor..will that make the engine run really rough if it is clogged....cause I know mine needs to be cleaned, and I get a cel from it.
:p
Alicia
96 Contour LX
2.5L V6 Duratec
DOHC
Stock of course!
BAD ASS GIRLS DRIVE BAD ASS CARS!!!
#50812 01/03/02 03:01 AM
sinned Offline OP
where exacly is and what is the MAF sensor? i'll try the rest right now smile
1995 Contour SE
champaign
