lean conditions are usually caused by low fuel pressure, vacuum leak, bad MAF, etc. 4 cylinder engines tend to suck the PCV line apart on the intake manifold (causing a vacuum leak). May also have a bad MAF (more common on V6). Need to check PID data (need a scan tool for that.)
