I have a problem when I get up to high RPM's. The lights on the dash (guages mainly) start to go dim and the charge light flickers when the car hits about 6k. I just replaced the alternator and now I don't know what the problem is. The back is just clips that plug into the back so I wouldn't think that would be the problem. Any advice is greatly appreciated. Thank you.
98 SVT 18" Enkei RS6's, NITTO 555 Extremes Intrax lowering springs K&N filter Sho-Shop Y pipe (without cats) Stock "gutted" manifolds Carbon Fiber Cowl hood Carbon fiber sail panels
Yep, sounds like you got a defective alternator. Sounds like the voltage regulator inside it is toast.
'98 SVT Contour, in at least 639 pieces 4 Speed MTX...synchro and shift fork replacement in progress
it is the alternator, but nor the VR. the brushes are getting kicked back by the commutator rings (rough). the fix is the same, replace the alternator.
I agree.
