#50665 12/31/01 05:30 PM
Red Offline OP
My wife's 96 gl has always had a low idle
when setting at light with ac on it almost
shakes car apart. It has a zetec i4.
Any ideas?
Black 96 gl
mostly unchanged
except for the urge to have it crushed
#50666 12/31/01 10:08 PM
MFE Offline
Clean the MAF sensor wires with a shot of carb cleaner followed by a shot of brake cleaner to eliminate all petroleum residue. 5 minute fix, works like magic.
Pacific Green '96 Contour LX V6, loaded
'98 Grand Prix GTP 14.88/91 bone stock, awaiting new times from 3.4 pulley, CAI, U-bend removal but it's creeping up on the...
Calypso Green '92 Mustang LX coupe, 13.56/101
3-time local class champion autocrosser
Racing school whore
#50667 12/31/01 10:12 PM
I too idle a little low 650ish. in going to try this. Why does it work?
98 csvt, no res, bm shifter, sho-shop intake.
"wherever you go there you are"
#50668 12/31/01 11:12 PM
MFE Offline
Becuase the MAF elements get dirty and the engine doesn't get a real read on the air it's taking in so it doesn't deliver the correct amount of fuel. The MAF may or may not play a direct role in idle speed but the information the computer takes from it at other times does.
Racing school whore
#50669 01/01/02 02:46 AM
I suspect that the Idle Air Control valve is stuck or sticking. Try cleaning it.
Jim Johnson
98 SVT
