#474897 11/06/02 10:07 PM
When ever I brake my steering wheel starts to shake considerable, my friend told me my rotors are warped. Is this correct, if so I will go get them turned....I have front disc brakes with rear drums on a 98 SE with 65k and a v6 duratech, i had new rotors put on in june.
-Jason, thanks alot!
Jason 00 Audi S4, 2.7 Bi-turbo quattro 01 S10 Xtreme, 4.3l 98' Contour SE with some mods 96 Cavalier (beater)
Most likely the rotors are indeed warped. Very common with these cars.
-Jeff -"Buck Futter!!" My Ride! http://members.sounddomain.com/sideoftheroad
could be the rotors, or your tires might need balancing.
if you drove in mud lately that could be it too, check for dirt on the inside of your rims.
I bet its the rotors, and your rotors should be still under warranty if they are from Ford.
95 SE MTX DH UIM, 65mm TB, SC CAI, Quaife, Centerforce, Fidanza, UR Pulley, F/R Strut Braces, Cross Drilled Rotors, S.S. Brake Hoses, 18" Enkei RS5, SVT Engine Mounts+Inserts, MSDS & y-pipe, Trubendz resonated exhaust & MagnaFlow cat
What brand and type of brake pads were put on??
99.999% certain it is warped rotors.
Cough up the bucks and buy new ones, they aren't that expensive. Besides if they have warped once they will likely warp again.
Thanks alot, they are brand new falken tires on there with the rs limited valkeryies on there (17s) so i do not think it is them, they were balanced and all that a month ago
FYI:
A common cause for warped rotors is improperly tourqued lug nuts.
'98.5 SVT E1 T-Red, Midnight Blue All stock
