So I'm driving to the hardware store yesterday and I slow down from highway speed and the stink of burning oil fills my nose. Get out look under neath the car and oil is dripping quickly from the oil pan and transmission. Pop hood, it stinks, i can see the structural holes on the mtx case are all full of oil. I feel the oil pressure sender on the engine block and it's covered with oil underneat. Rev engine and oil squirts out of the terminal post on the end of the sender.
There you have it, failure of the autometer electric oil pressure sender causes pretty big oil leak, but no major damage because it was caught quick. There is a huge mess to clean up.
I put the plug back in the block and called autometer. The tech says the senders have a higher tendency to fail when mounted dirrectly to the engine versus mounted to the engine via a hose. They are sending one in the mail.
The install was a little over a year old, and I've had no problems up till now. Might be a good idea for you guys with the gauges to inspect the sender with every oil change.
Cheers
JE
Cool Toe Chris
Cool Toe Chris
Thanks for the heads up! Guess what I'm doing next weekend...
Chris NJ 98.5 SVT Silver Frost
So what are we actually inspecting for? Any premature signs of wear and tear in particular?
Just wondering...I've had mine going on one year now.....i hardly drive the car but would still like to know. i have my oil pressure unit on the block.
Hugo ------ 98 SVT - 53k mi - SOLD 04 Mazda3 S 5-Dr
first check for any oil on the sender that would indicate a leak.
second loosen the wire nut on the sender terminal and see if the post is loose. i'll post a picture later of what mine looks like.
late
je
that would be cool if you could post that pic.
i'm going home and doing some work on the SVT tonight so that'll be a good time to check. Thanks for the tip!
Where exactly is the factory oil pressure sender located? And is this accurate and good for taking oil pressure & temp. Thanks Brian
'99 Black/Tan SVT #291 of 2760 Tinted Mirko Splitter Pioneer 8400MP & 3-way 6x8's Clear corners Custom SVT banner A-Pillar pod with Volt, Oil Temp & Press. gauges B&M Diamond Blue Fogs White HVAC the99svttour@yahoo.com
Here is what happened to mine..
for some reason its reading 12.5psi idle where it should be at 25psi and a little over 25psi WOT when it should be at 50psi can anyone tell me why???
99 T-RED 3L SVT Apillar Guages How-To 3L 98 CSVT SF/MB 4 SALE 7500 obo pm me
