#471441 10/31/02 07:24 PM
Is this TSB posted anywhere on the internet? I'd like to see the offical document and I don't want to buy the whole 1998 year Ford TSB from Helm.
98 SVT Contour 87 XR4Ti Merkur 69 BOSS 302
IAC Valve - Hooting/Moaning Noise
Article No.
97-22-3
10/27/97
NOISE - "HOOTING"/"MOANING" WITH A/C ON AND
ENGINE RPMS BETWEEN 2200-3200 - SVT VEHICLES
ONLY EQUIPPED WITH MTX-75 TRANSAXLE BUILT
THROUGH 10/31/97
FORD:
1998 CONTOUR
ISSUE:
Some SVT Contours may exhibit a "hooting" or "moaning" noise when the A/C is on and the engine is operating between 2200-3200 rpms. This may be due to resonance in the air by-pass valve and Idle Air Control (IAC) tube assembly.
ACTION:
Replace the air by-pass valve, hose assembly and gasket. The new valve and hose should reduce the possibility of a resonance noise in the air by-pass system. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
1. Remove and discard the air by-pass valve and retain the bolts.
2. Loosen the hose clamp. Remove and discard the hose and tube assembly.
3. Install the new hose and tighten the hose clamp.
4. Install the new Air By-pass Valve (XS2Z-9F715-BA) and Air By-pass Inlet Hose (F8RZ-9H308-AA). Be sure to install a new Gasket (E83Z.9F670-A) between the new air by-pass valve and intake manifold.
PART NUMBER PART NAME
XS2Z-9F715-BA Air By-Pass Valve
F8RZ-9H308-M Air By-Pass Valve Inlet Hose
E83Z-9F670-A Gasket
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
972203A Replace Valve, Gasket 0.4 Hr.
and Hose
DEALER CODING
CONDITION
BASIC PART NO. CODE
9F71S 42
OASIS CODES: 497000, 702000, 702100
E
E
Originally posted by ATL-SVT:
ACTION:
The key words being "should reduce". I guess they were a little off on this one.
1998.5 E1 SVT Contour #5482/6535
I agree with that one, I don't think it made any difference on my car at all.
What does this problem sound like? Anyone have a soundfile so I can hear it ?
1999 Ford Contour SE (Black) S&B Powerstack Air Filter Brullen Cat-Back Exhaust System (Loud Setup) Sylvania SilverStar Headlight Bulbs MSN Messenger: ddasilva99@hotmail.com
