Just a couple questions...
1: Can I convert quicktime media files to use media player? My d-cam only makes movies with quicktime, but not everyone has that program
2: How do I combine two video clips into one. (quicktime or media player) I want to make driving video to put onto cd, but I would like it all to be in one clip, not a whole bunch of small ones.
Thanks
Brandon Mendenhall '99 CSVT # 229 of 2760 '77 280Z Tomohawk Never rub another man's rhubarb!
I'm not sure about converting quicktime movies into other formats... I'll look in the dark corners of the web and see what utilities I can find to compromise Apple's video encoding... I think quicktime pro can save movies in .avi format, which are easy to get coverters for to make them other formats including media player's .wmv
As far as combining clips for media player... if they are in .mpg or .mpeg format, you can make your own clip combiner...
1. Create a new text file and rename it from "New Text Document.txt" to "mpg.bat" or "combine.bat" or something similar... just use the .bat extension... then right-click on that file and choose "edit"... type the following:
copy /b *.mpg new.mpg
copy /b *.mpeg new.mpeg
Then save the file and put it wherever you want...
2. To combine the clips, copy the .bat file into an empty folder along with the clips you want combined... make sure they are named in alphabetical/numerical order so they will cobine properly.... then just click on the .bat file to combine them... the new file will be named "new.mpg" or "new.mpeg", depending on which file extension the original files had.
3. Rename the new file appropriately.
BTW, this technique does not work for .avi files (they will not play)... nor for .wmv files (you will only see the first clip, nothing after).
Info for those unfamiliar with .bat files... a .bat file is from the older MS DOS operating system.... it is called a 'batch' file because it runs a batch of commands which are listed inside it.... was/is very handy tool for cutting down on manually typing commands at the C:\> prompt, as in the case of autoexec.bat which is called to execute its listed commands during boot-up of all DOS and most Windows operating systems.
'95 'stiqueLS 2.5L ATX S&B / CTA intake KEM Mag-Plus wires 1/4" TH fix Homemade heat shield Xenon bulbs Fog light rewire ATX cooler Flowmaster 942042 Blacked-out pseudo-chrome
thanks for the info. A little more complicated than I thought, but I'll give it a try.
once you make the .bat file, it becomes pretty easy... I keep a copy of it in a subdirectory of where I store my vids.... then if I need it, it is on hand...
