Posts: 4 |
This is my problem, the trunk on my 1998 Contour will not open with the lever inside, but it does work with the remote and key. I messed around with the orange nob thing on the trunk lock and in all positions it still will not work. Any ideas? Please help if you can. Thanks.
Posts: 2,382 |
When you pull on the lever inside the car is it very loose, does it pull back down on it's own? You may have a bad or broken cable. Have a friend pull the lever while you look at the lock, do any parts move? For some reason the Tour is full of cables...(throttle, door locks, trunk, fuel door) It's a forest of cables! Needless to say, if it's broken a salvage yard will have a replacement, but I have no idea how to change that one, the routing might be "fun"... Good luck Nate
"Fear is the little death."
Muadib.
Posts: 2,580 |
It could be that the trunk doesn't "pop" up, I ahd that on my 97. I had to pull lever, and lift up, if it was icy, trucnk only opend with the key. There is a small spring that can be added to make it pop up.
2005 Nissan Sentra 1.8 SE, Code Red. '00 Tropic Green Ford Escort SE [Contour's little cousin]
Posts: 30 |
Check the Valet lock leaver in the trunk, it's right below the lock mech.
My friend has a 98 and had the same problem when he got it.
Just my $0.02
95 SE V6 2.5L DOHC
5MTX, Post-98 Trunk Lid, Custom Air Intake
240K+ still counting
Impregnated Pontiac D.I.C In Dash
Pioneer KEH-5500
Crunch 200 AMP
2 15 Cerwin Vega DVC
I love my 'tour!!!
Posts: 16 |
Originally posted by 2000v6SE: It could be that the trunk doesn't "pop" up, I ahd that on my 97. I had to pull lever, and lift up, if it was icy, trucnk only opend with the key. There is a small spring that can be added to make it pop up.
I have that same problem on my '98! I've been looking for something to fix it. Can you give more details on this "spring"?
Posts: 2,580 |
I see if I can find part # from tech I know.
Posts: 16 |
Thanks...I would really appreciate it!
Posts: 192 |
Remove plastic
Loosen latch [2 torx]
Push down ~1/4 inch and tighten[trial and error]
Mine now works !!!!
1999 GREEN Contour SE SPORT Duratec V6, ATX, SUNROOF, 93,000 Miles, P0420 ON&OFF -replaced DS O2 --did not FIX
*New TORQUE CONVERTER @ 53,000-Intermittent P1744
*New DASH at 53,000 and New DASH lifted-now using MOLLEY bolts to pull down
