#467837 10/28/02 01:39 AM
Last night I was shifting into 2nd gear and as I was shifting to 3rd I let the clutch go and all it did was rev up. I coasted onto the side of the road and started my test. It will go into every gear but not go anywhere, in 1,2,3 it makes no noise, but in 4,5,reverse it makes a clanking noise from underneath the car. Has anyone else had any problems like this??
I was thinking maybe the shift linkage inside the transmission??
Maybe the rod that goes through the transmission??
Any suggestions would be appreciated.
thanks
98.5 csvt #4730 of 6535
#467838 10/28/02 01:42 AM
TGO Offline
do not try to drive the car. There is a chance a bolt has broken off of th shift linkage. The good news, it's a simple fix. The bad news, sometimes they fall into the tranny and get pushed through the side of the case. Get it flatbedded to the nearest dealer and get it looked at.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#467839 10/28/02 01:47 AM
Would a shop still have to drop the tranny to fix the bolt??
I am glad you know what your talking about, thanks for the info.
What would happen if the bolt has fallen in??
#467840 10/28/02 02:19 AM
H
H
Did you snap a cable? I did that not long ago. Replaced both at a hundred bucks a pop. Seem to fix the problem. Dunno though, maybe yours is an internal trans problem.
stock 1998 silver frost SVT E0 #1545 out of 6535 * K&N drop-in air filter * DMD * Koni's w/ stock springs * Autolite double platinum * Tranny cocktail * Mobil 1 Snyth Oil @ 60K miles
