#50181 12/22/01 12:53 AM
SVT#873 Offline OP
Recently I installed the limited slip differential and at first first gear was not working but then I solved that problem and now the clutch is slipping. Is it possible that I burned out my clutch using second gear instead of first for the few days that I did not have a first gear? Or does it sound like fluid got on the clutch itself? The slipping began the second day I started driving my car. When I finished the installation of the differential the clutch felt fine then all of sudden when accelerating the clutch felt as though it wasn't fully engaged.
thanx,
Jeremy confused
"Sometimes I find pickle slices in the sheets."
"Suck fist Dr. Dork."
Did you fit a new clutch when the trans was out?....if not sounds like you will have to pull it again....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
