Recently I installed the limited slip differential and at first first gear was not working but then I solved that problem and now the clutch is slipping. Is it possible that I burned out my clutch using second gear instead of first for the few days that I did not have a first gear? Or does it sound like fluid got on the clutch itself? The slipping began the second day I started driving my car. When I finished the installation of the differential the clutch felt fine then all of sudden when accelerating the clutch felt as though it wasn't fully engaged.
thanx,
Jeremy
