#466557 10/25/02 07:17 PM
HI THERE
PEOPLE ARE TELLING ME I SHOULD CHANGE MY WATER PUMP BECAUSE I HAVEN'T DONE SO SINCE THE CAR WAS BORN. NOW I AM AT 150,000KM.
WHAT IS A WATER PUMP?
HOW DO I KNOW IT IS NOT WORKING?
DO I NEED IT REPLACED WITH A "METAL IMPELLAR"?
1999 Ford Contour SE (Black) S&B Powerstack Air Filter Brullen Cat-Back Exhaust System (Loud Setup) Sylvania SilverStar Headlight Bulbs MSN Messenger: ddasilva99@hotmail.com
#466558 10/25/02 07:30 PM
click and click
1999 Red / Tan SVT #1969 of 2760 Built 4/21/99 K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links 17" FSVT 5-Spokes Factory Spoiler 35% Tint All Around
#466559 10/25/02 07:35 PM
I believe that your year has the white impeller, which is improved over the old impeller which is black.
I do not blelieve that there are any issues with the white impeller.
------------------------------------------------- 1996SE sports package, Duratec MTX No mods yet. 80K Kilometers. ------------------------------------------------- Wife has 1996GL Zetec ATX.
#466560 10/25/02 07:46 PM
A couple of weeks ago, I didn't even have an impeller.. I had lotsa black dust and debris though.. Now I have a metal impeller, a large bill, and no headaches!
Kyo 1997 Mystique GS Duratec ATX -- sold 2005 Focus ST - Quicker! - Still a Duratec!
#466561 10/25/02 08:45 PM
My 98.5 had a White Impellar.
When I replaced it at 60,000 miles, it had two vanes cracked.
Such an improvement ???
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
#466562 10/25/02 10:35 PM
Back in the cast-iron age a bad water pump didn't matter as much. All the new aluminum engines warp heads, spin bearings, or just die if they overheat.
Water pumps are a lot cheaper than engines.
Mine was about 50$, one hour, and one scraped nuckle.
#466563 10/26/02 04:30 AM
It would probably be safer to say the the water pumps with white impellers have less issues. I don't think it is correct to say that the white impeller completely ended the problems of the impeller falling apart.
#466564 10/26/02 04:45 PM
You asked how to tell if it's not working. You only have moments to see the temp gauge rising very fast, before your engine is seriously damaged. If the impeller is cracked and near self-destruction, there will be no external sign of it whatsoever. That's why people are replacing them proactively. Mine had some very small cracks at about 53,000 miles.
Were you just kidding about what a water pump is? It moves water from the engine, where it's heated, through the radiator, where it's cooled, and back to the engine. One of the things you can not go without except for a very short time.
'98 SE V-6 5-spd ASB Silver stock 89K miles in May '05 Like it for Oregon coast canyons!
#466565 10/26/02 08:04 PM
Z
Z
How many miles when yours broke? I have a 97 Mystique w/90k on it now. Thinking Timing belt at the same time.
'97 Mercury Mystique GS (Not mine anymore...) Now running a Toyota Matrix XR Red, 16" wheels, Sunroof, VVT-i
#466566 10/26/02 08:10 PM
If your going to do the timing belt then do it, but FYI the water pump failure are common in the Duratech's not so much the Zetecs
www.ChicagoCEG.com 2006 White Grand Prix
