#466090 10/25/02 12:45 AM
I know that I could scan the computer of my 92 Ranger using a volt meter IIRC. Can this be done with the contour? My cel keeps coming on for different thigs and I have almost spent enought to buy a scan tool just by taking it to the shop. Any input on this or should I just buy the scan tool?
98 SE Sport. custom catback, Intrax springs, 3L, 3L valves, APEXi S-AFC, 24# injectors. Other cars: 72 Challenger 360 motor 727 trans (used for parts) 73 Challenger 340 motor 727 trans 15.60 1/4 with bad miss and clogged fuel filter.
#466091 10/25/02 12:52 AM
Have you tried to take it to An Autozone. They'll check it and tell you whats wrong with it for free.
www.ChicagoCEG.com 2006 White Grand Prix
#466092 10/25/02 07:37 AM
'92 Ranger - OBD I
'98 Contour - OBD II
Sorry, got to have a scan tool.
#466093 10/25/02 11:54 AM
If I'm not mistaken, I believe that I saw two separate OBD-I readers at Walmart for about $20-30 each the other day. They had one for Ford/Lincoln/Mercury models and one for GM models.
#466094 10/25/02 08:22 PM
  Just in case anyone's missed the obvious, these will not work with a 1996 or newer vehicle.  I guess OBDâ??I didn't specify the method of retrieving error codes, and each manufacturer was left to devise it's own method by which this could be done.  The $20â??$30 gadget which is here mentioned is really just a slightly fancier way of doing what can be done with an analog voltmeter and some clip leads.  See <http://dalidesign.com/hbook/eectest.html>.
  OBDâ??II, used on all 1996 and newer vehicles, specifies a more complex manner of retrieving error codes and other data, and which requires equipment that is considerably more complex and considerably more expen$ive than the $20â??$30 gadgets.
  If you have an IBM-compatible portable computer, running Windoze 3.1 or later, have a look at <http://www.obd-2.com/>.
Hyster E60XM-33 1996 Mercury Mystique GS, Zetec, ATX To email me, remove the string HatesSpam from this address:BobHatesSpam@Blaylock.to
