No if anything it would just let dirt into the engine through the crack between the filter and the MAF. Lean running could be an air leak in the intake manifold. Check those two pipe going into the top of the intake manifold, behind the TB and see if anything is crackon the elbows, hoses or whatever they connect two. I had this happen to me and I found a broken elbow letting in air on the bank 1 side.
