#49968 12/18/01 11:59 PM
gmeeks Offline OP
My CEL has been glowing for over a year at least... finally got the code pulled and got a P0401 & P0420. The mechanic that pulled the codes told me it needed a new EGR valve and to clean out the carbon, etc. Pardon my ignorance, because I know very little about cars, but I just noticed that the EGR vacuum hose has apparently melted or been rubbed raw and it is broken in two. Could this be enough to throw the CEL's?
'96 LX / No mods
#49969 12/18/01 11:23 PM
yes
dion
98 SVT with some mods
http://communities.msn.com/contourstuff
#49970 12/19/01 02:03 AM
gmeeks Offline OP
Thanks for the response. I'll put a new one in and see what happens. I'm wondering if that hose was originally a soft hose or hard plastic? When I saw the break, I touched the hose and it was so brittle, it snapped in half again.
'96 LX / No mods
#49971 12/20/01 03:21 AM
  P0401 means you don't have enough EGR flow.  If the vacuum hose to the EGR valve is blocked or leaking, then the EGR valve won't open as it should, and you'll get this code.  This doesn't necessarily indicate that the EGR valve itself is bad, and in fact, it most likely does not mean this.  I understand that another common problem on Ford engines involves the EGR passages becomming blocked with carbon deposits, which would also cause a P0401.
  P0420 means your catalytic converter is screwed, but wait 'til you get the EGR thing straightened out before you believe this.  I've been told that EGR problems can cause wonky O2 sensor readings, which could, in turn, cause a false alarm on the cat.
{I do hate spam, but that isn't really part of my email address.  Remove the string ?HatesSpam? from the email address ?BobHatesSpam@blaylock.to? to email me.  No advertisements.  Spammers will be dealt with very harshly!}
Moonlight Blue 1996 Mercury Mystique GS , Zetec engine, ATX.  No mods. (Well, OK, one mod.  Before I got rid of my previous car, a 1994 Tempo, I swapped radios.  I liked the Tempo's radio better.  That counts as a mod, doesn't it?  I also kept one of my Tempo's wheels to use as a spare.  I hate those stupid ?compact? spares that come with modern cars.  Does this count as a mod?  If so, I guess I have two mods.  Replaced burned/melted blower switch and connector on 19 February 2002 with a 1P3T toggle switch from Marvac and a Molex connector from Rat Shack; I guess this now makes three mods.)
